BX14 1988 suitcase 150 engine carb problem HELP!!
Bx14
My Cars: Citroen bx 1988
Post by Bx14 »
Recent brought this, I’m a 27year old mechanic and carbs are way before my time.
Believe it’s a solex 34 carb!
Starts and idles as should, RPM maybe a little low but runs fine, slowly revving the engine it will rev up, soon as you move the throttle too quick it splutters, then catches its self then will rev with a little hesitation.
If the choke is about half way out it seems to rev fine, I suspect there’s some tuning or blockage, I’ve have the carb apart and cleaned, new plugs and fresh fuel!
Any help would be appreciated, sorry if this is dumb!
saintjamesy89
My Cars: 1985 Citroen BX19 GT
1990 Volvo 740 2.3 GLE Estate
2013 Nissan Leaf Acenta 24Kw
x 199
Re: BX14 1988 suitcase 150 engine carb problem HELP!!
Post by saintjamesy89 »
Could this be an accelerator pump issue? How did all the gaskets look when you had it apart? Any broken or hardened gaskets might not seal properly and be letting air/fuel in or out when the shouldn't!
AndreyK_bandsaw
My Cars: No BX at the moment - interested in classic Citroens
Post by AndreyK_bandsaw »
saintjamesy89 is on the right track — that exact stumble only when you snap the throttle, while a slow rev is clean, is very often the accelerator pump on a Solex 34. With the choke halfway out the mixture is a bit richer, which is why the hole disappears, so I'd also look at a lean transition rather than a basic idle mixture fault. After you'd already had the carb apart, it's worth checking the pump diaphragm, the little discharge jet/nozzle, and that the pump arm is actually moving when the throttle is opened quickly; off the car you should see a sharp, single squirt, not a dribble or a delay. A dried or torn gasket at the carb base can give the same snap-throttle hesitation by letting in extra air, so I'd re-check those faces as well. Once the pump squirt looks healthy, bring the idle up a fraction if it's on the low side — a slightly low idle makes that stumble feel worse than it is.
Metal-Cutting Band Saw Blades (DOI 10.5281/zenodo.23297044) | Stankotorg
