rear height corrector
tom
- Citroen Sorceror
Does the BX one match that of the Xantia?
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
i thought the link on the Xantia was only an intermediary link? the ball joint on the corrector is still the same witht he plastic pivot bit between the control rod and the HC. as i understand it, the reason for this arrangement is so that BX HC can be used! That said i seem to think the part numbers ARE different!
