1-7 TD pump.HELP
Geoffrey Gould
1-7 TD pump.HELP
Post by Geoffrey Gould »
Hello This is a YELL for help, the BX is being a Citroen, the injection pump has destroyed it's self in a big way. It's a Bosch, it __ does not __have the long lever on the outside thats connected to a waxstat. So a good working one is wanted please.
This is reasonably urgent, will collect if within striking distance of Bristol. If not it will have to be posted.
Thank you.
Geoff.
x 103
will get it in the post tomorrow Geoff, if i can find a spanner i'll remove the mounting plate to save on weight/postage, if you nee dthe mount plate let me know!
Geoffrey Gould
TD pump bracket
Hello Vanny Thank you for your reply. It would be easyer to leave the bracket on as it would save having to find the dial gauge to time the pump. It is somewhere in the chaos of packing and moving, I'm sure you know THAT one.
Please dont forget to let me have the details (Email address.)so I can PP some money to you.
Thank you.
Cheers.
Geoff.
