Dark blue 1.9 TGD estate, bought 8 years ago at 132,000 has now just turned 200,000 but still goes well, only fault is a slight water leak somewhere, did a run from south Wales to Swindon last week and had to top up half way back. Only other problem I can think of is that I didn't connect the heater controls back in quite the right place when the heater matrix was replaced so heating doesn't quite turn off.
New clutch (replacing the original!) and front spheres two years ago, exchange hydraulic pump and flow valve fitted last year as were both bottom joints. At this years MOT front flexi brake pipes and n/s drive shaft boot were replaced. Plenty of tread on all tyres, battery good, starts first time every time. MOT March 2007, tax January 2007.
All seats and and door liners changed for very good GTI ones about three years ago, also has removable boot liner.
Has been a faithful friend, including several trips to the south of France, but now want something a bit newer with air conditioning! Cosmetically there are couple of Tesco car park scrapes and some paint wear under the windows, minor rust on underside of one rear door only.
Open to sensible offers and anything else you want to know just ask, located in south Wales.
