I was fitting a s/h HP pump when I noticed some cracking around the preformed bend in the supply hose adjacent to the pump connection.
I tried to get the system to pressurise with no success, then I noticed that the hose was becoming wet with LHM on the outer side near the pump indicating a small leak.
I assume this was sufficent to prevent the pump from priming.
My question is can I use any type of hose other than the genuine Citroen item......in other words is there any significant suction that would collapse thinner walled piping ?
Tim.
