Front hub nut
Ian_Fearn
Front hub nut
whats the best way to get the 36mm nut off the driveshaft?
My breaker bar wont shift it.
Over and out from me
Captain Slow
Stewart (oily!)
Ian_Fearn
sleepy0905
Ian_Fearn
sleepy0905
- BX Digit man!
The key I find is to use big heavy sockets and bars. I have both a 1/2" drive and a 3/4" drive socket and powerbar for hubnuts. Often the nut laughs at the 1/2" drive, but the 3/4" drive shifts it with no problem at all.
Even my van, with it's 41mm hum nuts are easy-peasy with a 3/4" drive.
Ian_Fearn
Ian_Fearn
I bought a 3/4 drive socket set from an autojumble for about £30, OK it's cheap tak but it's never failed to shift BX.XM and Xantia hub nuts.
I would have thought you could pick up a long knuckle bar for just a few quid at a motorist discount shop. (buy one with a gaurantee)
Alternatively, you could buy a BX diesel auto and borrow mine at the same time
- x 94
Ian_Fearn
Ken, is this the ebay BX auto?ken newbold wrote:I bought a 3/4 drive socket set from an autojumble for about £30, OK it's cheap tak but it's never failed to shift BX.XM and Xantia hub nuts.
Kitch, i just thought the nut was a bit dodgy!
Will get a 35mm socket!
