I am actually contacting you on behalf of my dad, he has a BX 19 TZD Saloon which has started making a clonk noise from the rear.
The arm bearings were my first thought but we have had the car on the ramp at my work and the wheels are sitting ok, not obvious unusual leanings.
The noise isn't there all the time, it occurs if you jump up and down on the towbar like a maniac or drive over a speed bump or road with tree roots raising the surface, it doesn't seem to occur if you put the wheels into a pot hole etc.
This noise is a load crack, almost as though on a conventional car two ends of a broken coil spring had locked together and twisted apart again but as we know a BX is better than the norm.
We tried all manner of levering bits and trying to guess but I said I would try the internet because thats what I used to do when I had XM's and BX's in the past.
Thanks in advance for any advice
Adam.
owner of Peugeot 406 (I became afraid of the constant repairs with the XM V6 but I do miss it
