Need to change my cambelt on my TZD
Frequently asked technical questions and common modifications/improvements
I'm a bit confused here.
You have both front wheels free of the ground?
If you have then turning the wheel in gear will have no effect on the engine whatsoever as the diff will counter any movement you give to one side by rotating the other wheel.
So, maybe the brake was stuck on on the opposite side which allowed the engine to be turned over, but has now freed and therefore both wheels are turning and the engine is not?
Only other thing that springs to mind is that *possibly* one of the inner CV joints has parted company from the shaft?
TB2
Post by TB2 »
Ah, uhm, so, it is actually a good thing that if I rotate one wheel, the engine doesn't turn with it?
Yes, both front wheels are off the ground. If I rotate the front left wheel, which is still on, then if I check the other side I can see that the right side (where I took the wheel off) was moving, too. So that's normal? The engine only turns with the other wheel blocked? Well, guess that explains it then. So that's perfectly normal? I feel a bit stupid.
*reads wikipedia article about differentials
Ah, so the opposite wheel is actually turning the other way? Well. I see, that's pretty smart. I still need to read some more to fully understand it though.
But thanks. I get it now ;)
Carl
1989 16 Valve
Parts needed:
- One black leather headrest.
TB2 wrote:Yes, both front wheels are off the ground. If I rotate the front left wheel, which is still on, then if I check the other side I can see that the right side (where I took the wheel off) was moving, too. So that's normal? The engine only turns with the other wheel blocked? Well, guess that explains it then. So that's perfectly normal? I feel a bit stupid.
Yes, thats perfectley normal!
Diff's are very easy to understand, once you understand what they do!
Still, thats one problem sorted without any outlay of cash! Result.
RichardW
Post by RichardW »
What you want is a Technics Lego differential so that you can see how they work :lol: Remarkable simple solution to what is on the surface quite a complex problem.
I too have fallen in the "both wheels off the ground, can't rotate the engine" hole :roll:
I NEED a BX TD.
ellevie
Forum Treasurer
Post by ellevie »
Quote TB2: "I took a look at the manual and found out that the hand brake also locks the front wheels"
It ONLY locks the front wheels. Make sure to secure the back wheels with 4 suitable wheel stops. I don't even trust the handbrake --- I also secure the fronts wheels with stops when I have the back of the car jacked up.
You can get the timing marks into approximate position before you jack the car up by nudging the car backwards and forwards whilst putting it in and out of gear as often as necessary. Then you can do the fine adjustment with a wrench on the crankshaft pulley.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
YorkieTXD
Post by YorkieTXD »
Ian_Fearn wrote:Cheers David, i'd intended to do the pump and tensioner regardless.
This is a money no object job, i've wanted this car for years!
if its money no object, why not pay someone to do it. i have just been quoted £150 of a mate as he reckons its a four hour job.
Current 1993 19 TXD White
Previous 1988 19 Rd
YorkieTXD
Post by YorkieTXD »
okay why did i post this when it was sooooo long ago!
Previous 1988 19 Rd
This I have learnt : do NOT use a junior hacksaw handle in the flywheel timing hole, make sure it's a proper 8mm steel rod or drill bit with no play whatsoever as this is critical. If all the pins/screws are tight with no play the cambelt is straightforward.
I learnt this the hard way when the belt slipped and the pistons went up, hit the valves and broke the camshaft. If there is any play in the screws that hold the cam/pump pulley and the flywheel it's possible to jump a tooth when fitting the belt.
This thread is great. Hoping to have time to tackle the belt on mine this week. Am I right in thinking that essential items include a deep 16mm socket but that I can probably get away with not having to remove the crank pulley? On the advice of Mr Fenwick, the starter motor will be coming off.
I'm replacing the water pump (as it's leaking) and the tensioner (part of the kit so it'd be foolish to not replace it I reckon). Presume I need to drop the coolant before taking the pump off? If it hasn't all drained out anyway... :roll:
Yes you need to drop the coolant, I have never found the need to remove the starter motor but I would remove the crank pulley as it makes it much easier especially when fitting all new parts/belt and I like to see every part of the belt is correctly positioned on each pulley.
its not possible to change a cam belt without removeing the crank pully,
unless someone knows something i dont, i have been knowen to be wrong :shock: :lol: :wink:
JayW
x 13
Post by JayW »
citronut wrote:i have been known to be wrong :shock: :lol: :wink:
Well, this time you get away with it old man :lol:
For thou art correct.
Interesting. At least two people have said that it can be done in this thread...
JayW
x 13
Post by JayW »
Only if the plastics are missing! :lol:
x 20
/\ Agreed. I don't think you can remove the lower plastic cover (in one piece at least!) with the crank pulley still in place.
Starter motor is a matter of preference - makes it easier to find the hole, especially if it is your first time (should I rephrase that? :oops: ) and is very little bother on a NA diesel.
