Cigarette lighter replacement
timbo
Post by timbo »
Ok I'm back again.. the cigarette lighter replacement is slightly different than the original. Instead of having a shared "EARTH" with the body of the lighter. It has a separate earth wire. Can I jump this wire with the earth wire on the plug that fits the rear of the lighter power supply? If you know what I mean?? Also, the plug has 3 slots ie: power, earth and ???? what is the middle or spare slot ... is it an earth that I can use?? I think it is numbered 1, 2 and 3 on the slots.
Stewart (oily!)
Post by Stewart (oily!) »
Jumping it should be okay as long as you keep the centre contact positive, the extra wire is for the illumination.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
timbo
Post by timbo »
thats what i thought. The light has it's own power supply (red wire) and the power to the lighter is via the plug. I only have to share a common earth. On the old lighter it has a built in earth in the light fitting. but on the replacement it has a separate earth connection. Just a bit of wiring to do thats all. Cheers :D
