Fuel injector. Yellow.
Geoffrey Gould
Post by Geoffrey Gould »
Hi as above I need a fuel injector please, petrol, yellow.
Thank you very much.
Cheers.
Geoff.
ed4ferrets
Contact:
Post by ed4ferrets »
Geoff, I have 4 of them still attached to the GTi, you're welcome to them .... how do I remove without damaging anything #-o :? ?
'94 XM 2.1TD Break
'63 Renault Caravelle
Geoffrey Gould
Injectors
Hello Ed long time no speak, I hope sincerely that all is well with you ALL. They are held in with a "rail" which is in effect a tube that supplies them with fuel. once this is unbolted then the rail should be free and the injectors should be a straight pull out of the head. Note the word should there are rubber "O" ring seals that could hang on and a bit of a twist and pull may well be required to remove the injectors once the rail has been removed.
Thank you it is much apreciated and I will catch up with you in a few days. (Tied up with matters domestic at the moment.) A donation will be made.
Cheers.
Geoff.
Toddman
Contact:
injector
Post by Toddman »
Hi Geoff
I can pop one in with the injector service parts if you still need one - we picked up the bits today.
No charge for the injector.
Luke
Please call me Luke :)
http://www.bx16valve.com
Geoffrey Gould
Injector
Hello Luke and Ed Thank you for the offers. If you can do that Luke I would be gratefull. Ed I'm not ungratefull for your offer but this way you have a full set (4) to play with or dispose of as you wish.
Ta muchly.
Geoff.
Toddman
Contact:
Injector
Post by Toddman »
All sorted Geoff - will be posting parts in the morning :D
Luke
Geoffrey Gould
Thank you. Have a good weekend and I hope you are keeping well Luke.
Cheers.
Geoff.
