I'm looking for something only slightly more abrasive than t-cut and similar compunds
I want to rub out a slight, almost imperctible tide-mark - the furthest extent of my "blown-in" paint job?
The Finest wet and dry paper?
Gareth Wales
AndersDK
Barnsley BXer
sleepy0905
ed4ferrets
Also recommended if your BX has plaque or halitosisMarty wrote:Toothpaste.
You think Im taking the wee wee? Try it.
Seriously, toothpaste does the trick pretty well
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
Cornishbx16v
toothpaste also acts as a blue tack if you run out but its not recomended for sticking up wall paper!
the abrasives in toothpaste are very different to that of a compound! you woulndt want to clean your teeth with a cutting compound so why try and clean your car with toothpaste????
as an imediate last resort maybe! but i would rather leave it and use the proper products than 'bodging it'!
sorry guys but thats my thoughts!
