Aircon?????????????
Adam
Aircon?????????????
Post by Adam »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
It has been mentioned on other posts that this car may have aircon? I'm going to have a look tomorrow and it's mine if I want it. How can you tell as I don't see any obvious signs from the pics???
Many thanks.
Adam
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
1991 TZD Turbo (Breaking)
"Graculus" 1990 TGD Turbo (Restoring)
artic-steel
Post by artic-steel »
I have aircon on my Grey GTi & it has slider controls below the heater dials, so if you can see them in the pic ,Bingo
artic-steel
Just looked, & being honest i can't see them
Adam
Post by Adam »
Me thinks it doesn't then, I had assumed the slider was above the heater controls as can't see where there would be room above the ashtray, pointless coin holder thingy!!!!
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
Ian_Fearn
Post by Ian_Fearn »
Look on the underbonnet picture.
You can see a pipe coming up on the far right of the picture out from the radiator vacinity. This is an air con pipe.
Over and out from me
Adam
Post by Adam »
Indeed, very obvious now you've pointed this out, all my others have not had this, however it brings me back to the controls, not obvious from pictures. Guess i'll find out tomorrow, can't wait!!!!!!!!!!!
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
I think I can see the left hand slider switch. Also seems to have ABS and possibly 2 electric mirrors - I see the usual 4 way switch in the auxilliary panel but is that a selector next to it?
Also seems to be the only one without a leaky camshaft oil seal! Should have 2 fan motors rather than the 1 of the Mk 2 cars without AC.
roscoe
Post by roscoe »
Only has 1 electric mirror as per normal TZD - the drivers' door mirror has the manual control on it. Can't make out the A/C slider controls behind the steering wheel which blocks the view of them, but Ian is right - the pipe on the right hand side of the rad is the A/C pipe to the condenser.
Looks like a very tidy car for the price - could be as simple as no LHM or a loose HP belt, or the bleed screw needs cracking and retightening...
cheers,
Roscoe
1991 TZD
2004 Peugeot 307
You lucky devil! I want it myself now!!!
I have a complete air-con kit for a bx I bought some time ago but haven't got round to fitting yet. The controls for it are mounted on the handbrake shroud? Never seen another bx like this but I'm told it's the earlier spec (def a 16v unit, smaller condensor to fit infront the rad).
Buy it! You know it makes sense!
Chris G
