Ride height
sleepy0905
Ride height
Hi can anyone give me any ideas my suspension works fine no problems no leaks etc but when i set the lever inside to the intermidiate position ( the one between full up and normal) my car goes all the way up and I am baffled as to what is causing this I have cleaned and greased all the linkages ?
M
http://www.stevenbraud.demon.co.uk
Gives techno details on the Hydro system.
It may be that your height lever doesnt have the notch propperly carved out for the car to sit at the intermidiate height. (This is common on the Xantia - my own suffers with this). have a look to see if its resting propperly in the intermideiate notch, otherwise the only thing which springs to mind is the height controler at the rear of the car.
sleepy0905
