Need the green T piece that couples the clear breather pipes onto the top of the LHM reservoir.
Drew a blank at GSF and the stealers.
Any ideas on where they (or an alternative) may be available from?
T piece
AndersDK
Are you hysteric about the green colour ?
Warning : large grins ahead
warning : evil foolish grins coming up
muahahaha
use a standard WHITE t-piece as found for sprinklers, airhorns etc.
- and paint it green
If you experience trouble finding a WHITE t-piece - then ask for a BLACK Y-piece instead.
- but these requires 2 layers of green paint
Anyways my bet you'll have trouble paying more than 100pence for it - except if you insist ...
Hi Anders - Have you been on the Elephant beer tonight ?
Must get back to Copenhagen to try some more of that.
I will go for any replacement in any colour of the rainbow (or clear) that is able to survive being hit by the bonnet each time it is closed.
I have tried a few times but as this is something worth only a few pence I havent found a vendor with sufficient enthusiasm yet!
Re: T piece
If you really want green, and indeed the proper part, they are still available from any citroen dealer for less than a couple of quid. I@ve just moved house so everythings a mess and I cant find the parts list but they'll def be able to supply you with oneWay2go wrote:Need the green T piece that couples the clear breather pipes onto the top of the LHM reservoir.
Chris G
mnde
- Meteor Man
Adam
