BX 17TD Transmission Oil.
Adam
Post by Adam »
Is there a specific type I should be using, i'm pricing up the TZD overhaul and want to get everything at the same time and blitz everything in a few days hard work.
Thanks Again
Adam
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
1991 TZD Turbo (Breaking)
"Graculus" 1990 TGD Turbo (Restoring)
Stewart (oily!)
Post by Stewart (oily!) »
Total BV sae 80 oil is needed, I found total 80 grade at my local garage, you will need 1.8 litres, it fills from the 19mm plug on the end of the gearbox under the nearside wheelarch.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
