Smoked plastic panels on Mk 1 'C' pillars.
Baldbazza
Anyone got any tips how to get rid of the crazing, scratches, cracking, whatever it is, that affects these? An old problem - my first BX of many summers ago had this when it was only 4 or 5 years old.
I once saw some that had been painted black. Looked awful!
1985 BX 19 GT
2007 Alfa Romeo GT
2007 Alfa Romeo GT
adamskibx
Ive been trying to track these down for ages. I dont think we'll ever come accross unused ones now. The best option is to find an old scrapyard TRS with good ones (and you do see them), and then use heated welding wire to slice through the bond (apparently thats the only way to get them off without cracking them). Basically get some thin welding wire, hold a lenght between two long sticks and connect the excess length to a large car battery. Then get the wire behind the window and slowly pull accross the underside of the plastic to cut the bond.
Just a tip in the meantime. If yours have a horrible mix of coloured crazing , try a driveway pressure washer on them (without getting any direct jet on the rest of the car). This worked wonders for mine, but they still could do with replacing.
edit- also, these windows also exist on the TRS MK2 BX's, and are the same part.
Baldbazza
Ah, but the point is that my first BX, a 1984 16 TRS that I bought in 1989, was affected when I bought it. So, even if I can find new ones (and I'll probably try), I guess they'll also be affected in a short time.ken newbold wrote:Replace with new ones.
As I plan to keep hold of the GT long-term I'm keen to find out how to prevent this happening (and, by definition I suppose, to find out what causes it) or, preferably, how to treat it.
Is a body shop likely to be able to polish this out?
1985 BX 19 GT
2007 Alfa Romeo GT
2007 Alfa Romeo GT
tim leech
Just a thought
As these are relatively small items that would fit in a domestic oven, could you not make your own out of a sheet of plexiglass (ICI Perspex)?
Make moulds by pouring non-toxic thermosetting mixture of some sort into the inside of your originals.(release agent on original first!)
Or make with Wood and Spokeshaves by trial and error for the more talented.
Place mould with plexiglass blank above in oven and heat until perspex droops over mould. Remove, cool, trim & fit
Colour with spray on tint.
Note: If this is tried you must pay attention to ventilation and fumes.
Baldbazza
My wife's just padlocked the oven.....Way2go wrote:Just a thought![]()
Interesting idea, but probably beyond my scope at the moment. There's also a pattern etched/printed in/on the plastic that would be tricky to replicate.
1985 BX 19 GT
2007 Alfa Romeo GT
2007 Alfa Romeo GT
sleepy0905
Hope this helps but here are the part numbers and price for the ones for my 1990 1,9TZS Left 96008918 £64.86 inc Right 96008917 £64.86 Inc this is Since RP 04131 althought the earlier one until RP 04130 having part numbers 95635189 95635190 I have been told is the same as the later ones but i dont know if this is true.
adamskibx
- x 94
sleepy0905
Or try some of this I used a military equivelant when i was serving on my watch when it got its glass scratched it removed vurtually all of the scratches.
http://cgi.ebay.co.uk/Aircraft-Plastic- ... dZViewItem
roscoe
The aircraft plexiglass scratch remover that Sleepy mentioned should work - I used it on my plane when I was flying back in Canada and it worked a treat to remove crazing and scratches from the windscreen. Can be picked up from most aviation supply shops and with some elbow grease will make old plexiglass and clear plastic look like new.
cheers,
Roscoe
1991 TZD
2004 Peugeot 307
Roscoe
1991 TZD
2004 Peugeot 307
