FREE rear arm with ABS
Gareth Wales
Post by Gareth Wales »
.....its the driver-side, with an OK hub. Only fault is the ABS holder has been cut into to remove the ABS. No problem really as I araldited an ABS into a similar one. Or the holding ring can be repaired by a simple braze.
Can deliver at the Chumley meet on the 3rd.
Gareth
