Ebay calipers- Beware
tom
Citroen Sorceror
x 38
Post by tom »
http://cgi.ebay.co.uk/Citroen-BX-Visa-B ... dZViewItem
I can see that the slides are painted. This isn't how they ought to be so I would be very careful about bidding for these items, that is, I wouldn't!
AndersDK
Post by AndersDK »
What difference would that make Tom ?
Once bought a pair of recons locally (brand unknown) - painted yellow all over - had no problems whatsoever with these calipers ?
Keeper of the site Goat
Post by cavmad »
I got a brand new one from M&M in Holmfirth a few months ago for considerably less than half what this seller wants for two. Genuine part too, well packed and quick delivery, I think they said they had some more knocking about at the time so probably worth a call if anyone needs one.
It has to be said they were also extremely helpful and polite too.
Vauxhall apologist.
tom
Citroen Sorceror
x 38
Post by tom »
The sliding parts should not be painted. Fitting the bar at the top would almost certainly cause the pads to bind in the housing. As the paint wears away, there is the risk that the pads will sieze and that is not a good idea.
I agree, and I've seen stuff from this guy before, wouldn't buy anything from him....
Chris G
Cornishbx16v
Post by Cornishbx16v »
i suspect the reason for them being painted all over is that they are more than likely powder coated and have been stripped down before coating!
Timmo.
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16v.co.uk/forum
www.bx16valve.co.uk
tom
Citroen Sorceror
x 38
Post by tom »
Very likely they have but it still is not the correct clearance for the pads. I am surprised that a well known outfit like EBC would do that.
Although I would have thought this too, many of the calipers I used to sell at various factors were like that and they worked fine.
The paint rubbed off fairly quickly if it needed to, although alot had a bit more float in them. Couldn't remember the brands though, some were Delphi. But throughout thie entire world there are only a handful of hydraulics specialists....they recon them and send them out in various different boxes for different brands.
AndersDK
Post by AndersDK »
Kitch wrote:Although I would have thought this too, many of the calipers I used to sell at various factors were like that and they worked fine.
Exactly what I thought.
There are such big forces from the vibration and heat in the brake pads that a layer of paint wont hold the pads. Not even rust can hold the pads here. Its always the slider bushes sliding un-evenly or getting dry that makes for un-even pad wear.
