OK -did the temp gauge conversion tonight - ended up robbing the sensor out of a 16V 'wreck' I just picked up (previous owner knocked a hole in sump and kept driving it until it 'rattled') - the car is complete and runs fairly well once it has oil in it
- but that's a job for another day..
I swapped the 105C temp switch in the TZD with the sensor from the 16v, pulled the instrument panel out, took out the right hand panel with the unused top part and temp warning lights on the bottom, swapped in the gauges I got with the other 16V panel, connected everything, tested all the bulbs and replaced a few burnt out ones, and used a spare connector in pin 6 of the 10 pin connector to hook up the single lead from the sensor (single wire on 2 pin connector at bottom of panel. Reinstalled it back in the binnacle (bugger of a job!!), hooked up the battery to test all the lights and found out half of them weren't working
Took the oil level sensor housing off (again) and rechecked those bulbs, plus the ones along the speedo - all OK, so reassembled it and retested - they all worked
Put everything back in place, gave it one last check to ensure all the lights were still working (parking brake didn't but wasn't working before - so need to start at the switch end on that one and find out why), and took it out for a drive. Took quite a while for the temp to come up (a km or so but it is pretty cool here tonight), then it sat on about 85C the rest of the time - didn't thrash it to see if it would go higher as my &*%$ rocker cover gasket is spewing oil everywhere - so tomorrow its off with the intercooler and try and reseal it (again). Did it last night with silicone gasket goo, but if anything it's worse now. Anyone got any handy tips for getting those things to seal properly?
I've got some pictures of the temp gauge job but haven't figured out how to post them yet - will do it once I sort that out.
