Due to an impending move to Devon, my hoard of Bx's and bits will have to go!
Have a complete late TZD Turbo engine and box removed when car was written off (thanks son). There is also a 1.7 turbo D engine minus the fuel pump, plus a spare td head. New td clutch kit in a box, new water pump, octopus harness, rear curly brake pipes etc, etc. There is a fuel pump and matching injectors to suit a n/a 1.9 diesel, rebuilt at great expense by my mate at Lucas, he took so long to get round to I had already sold the car!
Don't have any panels, subframes seats or doors but have a number of front struts, wheel hubs, discs, calipers and hydraulic parts. Location is B28 0Tl so if anyone is heading down to Citroen meet in Stratford this weekend, they could call and collect any bits on route. Looking for beer money prices rather than scrap stuff!
Also have my white K plate TZD estate to sell. Has about 11 months mot but is currently sorned. My friend also has a a red h plate gti 4 x 4 which needs to go, plus red g plate two wheel drive gti. Both need bits of tlc but neither of us has time!
Unfortunately all three are in his barn and he is away at the Automechanika Trade Show in Frankfurt this week. Superb timing!
Let me know what bits you are looking for!!! Regards Jeff
Bx clearout
zebedee150
Bx clearout
Bx'less after 12 years
- x 25
zebedee150
Registered August 1992 on a 'K' plate. It has been mine since April 2003, complete with new windscreen, and been all over the place! I think it has about 180k on it, not as fast as my old TZD but does not use oil either. (leaks a bit)
Has been my 'spare' car since October last year when I was travelling to Weston super Mare and fancied a bit more metal round me! Enter the Zantia.
BX has towbar, roofbars and apart from a couple local rust spots is quite straight. The abs works as and when it feels like it, I had hoped Roy would break the 2 wheel drive gti, so I could rob a couple of wheel sensors off it!! Needs new bearings in the rear arms ( have the kits) and the clutch is getting heavy ( have clutch kit). Also needs bottom rear engine mounting fitting ( have new one in spare ally casting)
Had to weld the top door hinge and rear of the nearside sill for the mot, its had new battery, spheres and rad in the past couple of years, plus I did the cam belt when I got it.
Hows that sound? Regards Jeff
- x 25
Thanks for the info. I will be looking for something with lower mileage. Having said that, the car sounds interesting for someone who might have more mechanical and extensive DIY skills than me, so honestly I do wish you best of luck - I'm sure you'll find a taker
Last edited by Philip Chidlow on Wed Sep 13, 2006 8:07 am, edited 1 time in total.
- My Cars: BX GTi, C3 Auto
- x 113
Do you have any of the following for my Turbo Diesel......
Rear hub(s) + ABS
Lucas/RotoDiesel injection pump
Gearbox
If so then I will have them. I cannot come and collect before October 6th though as I am away from home at the moment.
Rear hub(s) + ABS
Gearbox
zebedee150
zebedee150
sleepy0905
- x 113
