Any common causes?
Puddle
- x 94
- x 94
- x 94
Just had another look, this is actually quite bad! I think its the O/S rear sunroof drain pipe at fault. Theres water coming in through above the rear door, down the B pillar, down the inside of the door and through the rear speaker
The puddles about an inch deep on top of the carpet, then if you press down on the wet carpet it moves about like a water bed and theres laods underneath
And my garage is inaccessable to put it in
- Our Trim Guru
Used to park a leaky one on a hill in particular orientations to avoid a blocked draintube, or manoeuvre it so as to send trapped water down the good tube. Rear tubes can leak all over the place - the rear footwell is perhaps less likely but try raising the rear seats - you may get a nasty surprise.... there's a water-collecting hollow here. You may be looking at a secondary puddle.
- x 94
BackinaBX
I had exactly the same problem with my first BX... within a few days of owning it the foot well behind the drivers seat would fill up with water. Took it back to Citroen, they cleaned out the roof drains... bingo, no more water.
Better get that thin wire out and give those drains and good going over... that will fix it.
"I'm not into art, I'm just a gun for hire" - Helmut Newton
_________________________________________
'91 BX 19 TZD - now with added dent!
'91 Saab 900 Turbo - thirsty, expensive & beautiful.
I would agree with everyone else on this problem, blocked drain hole(s). When i was setting off for the Cholmondoley meet when the suspension was rising i heard trickling water.
Looked behind me & i saw water pouring out of the rear speaker (must have been a couple of litres) on the driver side, good job i dont use them as they were crap anyway. At the meet it was suggested that the drain holes must be blocked.
Took it to my local garage & they have air blasted them out, they did report seeing a fair bit of filth coming out & by all accounts the entire roof area is like a water tray, so when they are blocked it just fills up & can pour over the top, which sounds right as i had noticed that the headlining on the drivers side was damp on occasions.
Hopefully mines now sorted, someone on this post did suggest wire, i thought u shouldn't do this, as the wire could damage the plastic pipe, air is safer? I might be corrected on this point though..... Best getting it done before winter otherwise you will get ice on the inside of the car as i found out last year... Nice...
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Kitch wrote: Theres water coming in through above the rear door, down the B pillar, down the inside of the door and through the rear speaker![]()
I'm confused
Previous experience for me has been that the tray fills and simply over flows into the 'B' pillar shoud and runs down that and out the bottom into the rear wells (well under the front seats that then runs backwards). Just a bit confused how it gets from 'C' to 'B'?
As an aside, pugs dont seem to have clear plastic tubes, but black rubber tubes and these dont seem to get mould in them or get blocked up! Anyone had experience of swimming pools in Pugs? (older *05 series pugs i mean!)
- x 94
Cornishbx16v
Could be that your drain pipe for that side is no longer attatched then if its that bad!!!!
defo pipes though of some description! i cleared mine out via airline from the end of the pipe at the rear light! the theory being if its blocked then its got blocked running down the pipe and its easier to blow the blockage back the way its come than force it the way its blocked!!!!
not had nay issues with mine since doing it in 2003!
- x 94
- x 25
I think mine are black - certainly the front ones. I'll check the back ones. Where is the top end of the back ones in relation to the sunroof aperture?Vanny wrote:
The only problem with leaks/water intrusion I have is, after washing the car, I seem water gets through the rear C pillar vents and into the boot.
