BE3 Gearbox
sleepy0905
BE3 Gearbox
Post by sleepy0905 »
This is free and in good order came out of my old 1.9TGD Hreg
djoptix
Post by djoptix »
At the risk of giving away what I'm thinking, is this the box which can donate its 5th to a 16v box for more comfortable motorway speeds...?
sleepy0905
not sure but i think someone else will be able to answer your question.
x 103
Think you want a turbo box '5th' cog, but ask Mike E as he's done it!
Barnsley BXer
Post by Barnsley BXer »
Ey up Sleepy,Wiz tha bin.This translates to "Hello Sleepy where have you been"Haven't seen you on here for a while.Are you making a comeback?
1990 GTI 4x4
1992 TZD
sleepy0905
Im getting there had a few personal problems then health problems so i have been a bit busy but getting there slowly I am having a clearout and desperately need this box out of the way and i dont realy want to scrap it as it is good.
Anyhow hows you.
My Cars: BX GTi, C3 Auto
x 113
djoptix see this http://bxclub.co.uk/forum/viewtopic.php ... highlight= to see if it will work for your model of BX.....
Hi Sleepy. Good to have you back. :D
sleepy0905
Thanks phil still not totally out of the woods but i have now got to slow down and behave and do as i am told so scrabling round on cars is out of the question so over time i will slowly be clearing out and there could be more bits and pieces going to good homes.
djoptix
Post by djoptix »
I think that would suggest it will work...? I know the ratio jump from 4th to 5th will be a bit extreme but since the car will happily do 100mph in fourth, I find the first four gears are fine for most A-road zooming around.
Mike E (uk)
Post by Mike E (uk) »
Fifth gear cog set is reqd from a turbo D.
38/25 and 63/16 teeth.
The bearing needs to be machined down a 1mm too.
gives 23mph/1000rpm
Mike
sleepy0905
Right folks this is last chance saloon as if no one wants it then it will have to go for scrap as i need it out of the way ASAP.
Surely someone must want it even if it is just for a spare as it will be a shame to scrap a perfectly serviceble box.
