![Citroen ^^ ^^](./images/smilies/citsmillie.gif)
Grease nipples
Grease nipples
Any of you fella's know where i can find the topic on fitting grease nipples to radius arms, i would like to get a bit more mileage out of them, and thinking of doing mine in the very near future. ![Citroen ^^ ^^](./images/smilies/citsmillie.gif)
Citroen the thinking mans car, i think im off for a pint while i think about that tricky hydraulic job!!
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Try this: http://www.aussiefrogs.com/snippets/grease.htmI've not read it but it should help ![Laughing :lol:](./images/smilies/icon_lol.gif)
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 85
Ian_Fearn wrote: After doing a few rear arm bearings i'm not convinced grease nipples will do anything at all.
it depends on which technique you follow, theres possibilities for some of them, but all the technique i've seen misses huge big steps and thus probably won't work! However keeping the bearings well lubed can only be good for them.
Best thing to do is undo the bolt over 10,000 miles and rotate the bearings through 180 degrees, shame its not so easy!
