car wont start
so what order should the spark plug leads attatch to the distributor cap???
hayes gives order from the fly wheel as 1342 but how does this then tally on dis cap???
ta
charlie
Thats quite usefull to know , i assume that only works when the cars going forward though? (like if it was in reverse, the engine doesnt go backwards?)AndersDK wrote:The engine axles turns the same way as the wheels - so does the distributor rotor arm as this is locked to the cam axle.
Thats a handy rule of thumb to remember.
How awfully amusing this comment of yours VannyVanny wrote:Thats quite usefull to know , i assume that only works when the cars going forward though? (like if it was in reverse, the engine doesnt go backwards?)AndersDK wrote:The engine axles turns the same way as the wheels - so does the distributor rotor arm as this is locked to the cam axle.
