On start up, from cold or hot (after being turned off for a few minutes plus), the revs are low by about 200rpm. Over the proceeding 60 seconds or so, the revs slowly rise back to 1100 ish when cold or 900 ish when hot.
I have experienced air in a rotodeisel, but having read various posts on this subject, it seems that air may affect the Bosch in different ways. Could the above description be indicative of air seeping in then being purged out somehow? It also takes up to 3 seconds to start without preheat when hot.
None of the above symptoms occur when starting up immediately after switching off.
Any ideas - it's not causing a real problems apart from my mental health - I hate even the slightest mechanical fault
