Have the front screws out (near the steering wheel) but the clocks seemed to be either hinged or attached to something at the back. Any ideas please before I take my biggest persuading stick to them in a fit of temper?
Clock removal!
- Keeper of the site Goat
Clock removal!
How the blinking heck do you get the dashboard clocks out of a BX? I can`t believe I`m asking as I have removed two sets before without trouble and now I`m struggling
Vauxhall apologist.
sleepy0905
sleepy0905
Stewart (oily!)
Sometimes its not a thumbscrew but a kind of pressed steel nut, for these I use an 11mm socket gripped in my fingers, the rh side one is accessed through the knee level switch pod hole, remember to catch the black rubber washers and refit any bits of spongy material in there (squeak prevention)
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- x 94
Erm, knee level switch pod hole? Is this where the bottom steering column cowl is and somewhere near the dimmer switch for the dashboard lights?
I`ve already carefully removed the cowling, well I started carefully anyhow. First two or three screws came out ok, the two behind the steering wheel didn`t want to play ball though so cowling was `gently` removed using a lump hammer. There are now various bits of black platic strewn all over the interior
Vauxhall apologist.
sleepy0905
mmm....I found you had to remove the steering wheel first to get access to these torx type screws?cavmad wrote:First two or three screws came out ok, the two behind the steering wheel didn`t want to play ball though so cowling was `gently` removed using a lump hammer. There are now various bits of black platic strewn all over the interior
Is this a spares car that you are cannabilising?
