ENGINE MOUNT
tim leech
ENGINE MOUNT
How hard a job is it to change the big round rubber engine mount at the bottom, I know there cheap enough to buy, but is it something I can do in ten minutes with a socket set or am I best to let the guys at work do it?
sleepy0905
I did mine not knowing if the technique would work - have done many worse jobs - takes sometime to hacksaw through the outer ring. You should also do the small bush at the back of the yolk.
Freezing is important - as you need all the help you can get to fit the new bush - worth making sure its got a small bevel on the leading edge (the one I used had a slight chamfer as a result of some part of the manufacturing process) and be prepared with tools ready before you remove it from the freezer - so you can get straight on with the job. I also greased it - and it went in quite well.
If I could get someone else to do it - well yes I'd miss the fun and let them!
sleepy0905
citroen7
tim leech
- x 94
Wheres the fun in that? No grazed knuckles or excuse to practice french swearing........ on second thoughts....Kitch wrote:I just bought the mount with a new housing complete.
Chris G
Brian
Hi Folks,
Well, depending on how damaged the existing mount is, I was getting oscillations on low speed acceleration.
Inspected the lower bush, not too bad, a little slopy, so made up two curved metal plates that would fit into the two gaps in the rubber, secured them with silicon sealant, and bingo --- problem cured..
Worth a try !!!...
If any one is interested can take and post a photo ...
Worth a try !!!...
