Windscreen wiper washer problem solved!
AdamH
I have found two companies on e-bay that sell wiper blades with built in washers that spray directly onto the windcreen, as found on Merecedes, should solve the problem for those of us who have problems with the washer spray arm blocking. To find them do a search on "storm wipers" the are £4.99 + post, this is just for the blade, there is another company wich comes up from the same search, but sells you the entire arm as well, I think this was for around £29, the seller has confirmed he can sell the right arm and blade for a BX. I am going to order the £4.99 blade only, will let you know what i think of the quality etc........
The difference between 'involvement' and 'commitment' is like an eggs-and-ham breakfast: the chicken was 'involved' - the pig was 'committed'.
1990 BX 1.7TD Estate
Stewart (oily!)
