Paint scratch repair
Gareth Wales
Post by Gareth Wales »
Although the words Granny, Eggs and Suck may come to mind, I’ll make no further apologies before sharing my way of dealing with scratches and paint imperfections which are too marked to be successfully treated by rubbing and flatting compounds of the G3 and T-cut ilk.
Tear an irregular, jagged-edge hole in a sheet of newspaper big enough to surround the damage, with an inch or so margin. Tape the masking paper in place and spray undercoat, topcoat(s) and lacquer coats as usual , When the last application has flashed, remove the paper and wait around two weeks for the paint to harden, Then compound as usual. I’ve found that trying to touch in scratches with a fine brush or similar never really works, and , even during the two week wait the repair is almost invisible particularly with a jagged-edge paint patch.
BTW
A really excellent fine and final cutting compound can be made up from a paste of cornflower - this tip comes with due acknowledgement to to the respected and much-missed AlanS
Does that technique work on metalic?
Terry Brooks
Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Post by Terry Brooks »
At the risk of "hi jacking" Gareth's thread :oops: ........the way I've dealt with metallics is as Gareth describes ...and then tear a slightly larger hole in another sheet of newspaper and apply clear laquer over the touch up,and then rub down after a week or so.
I did a reasonable repair on a mates BMW :oops: :oops: [he's a good mate and not yer typical Beemer driver .....honest! :P :oops: :wink: ] .....where the laquer had started to lift.
TErry
Gareth Wales
Works well with metallic- that's what I've got.
Terry's idea of enlarging the paint window is something I'd recommend.
Cheers for that, might try that when i get some free time. Will post results of course (perhaps before & after piccies as well).
Re: Paint scratch repair
Gareth Wales wrote:- this tip comes with due acknowledgement to to the respected and much-missed AlanS
:?: AlanS still posts the occasional one but yes, the frequent and detailed postings are missed. :(
Hopefully you are OK Alan? :?
