Ive swopped the both tonight with the help of tim 2cv (ta mate) and its made sod all difference, Ive tried two more switches which I know work as they do I my 16v and still nothing! The passenger window switch from the driver door doesnt do a thing either (up or down) and ive tried a working switch on that too! Ive had the motor off to make sure it wasnt sticking but both motors only work one way!
We had BOTH door panels off to check its all connected up and everything is as it should be!
You can see the interior lights dim when i try and raise the window even though its a full height but when I try and lower it it doesnt flicker??
Tim and I then took it for a run where it drove faultlessly, I turned it off and went to start it again immediatly afterwards and now it wont start! It turns over fine but wont fire! HELP!
Is there a fuel cut off switch on these? It feels like its not getting any.
