TERMINAL PROBLEMS?
tim leech
TERMINAL PROBLEMS?
How easy is to change battery terminals guys, mine are all worn and battered and wont tighten up properly on my 16v
Stinkwheel
terminal clamps? On the ends of the leads?
Easy, just go and get some lovely brass ones from an accessory shop, cut off the old ones, bare some clean wire on the leads and screw into place the new ones (packed with grease if you have any sense too)
If you cant find any give me a shout, Im pretty sure i have some in the shed somewhere.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
tim leech
Bodgers cure is to wrap some clean lead sheet round them and tighten! Otherwise earth straps can be bought in accessory shops - as can power leads - complete with terminals. I think the power lead goes through the junction connector under the battery. What I can't remember is if it goes straight through insulated from the other wires using that junction or if it is taped off there. If it goes straight through - then you need a positive terminal/lead that will go straight to the starter. If its tapped - put the new lead on the starter with the old one sharing the terminal and cut the old lead off on the battery side of the connector (and insulate the stub)
Cut the terminal with a small hacksaw but dont chop the wires off!! It's easy enough, even I can do it!
My valver has shiny Gold terminals, they aint cheap but they look brill and have lots of "ports" to add extra looms for stereo etc..
Chris G
Chris G
Toddman
terminals
As above - just fit nice new terminals.
You can get them with extra take off points and the length of the leads is not a problem.
I changed mine as the std ones had stretched.
Luke
Luke
Toddman
I often think yo myself "Another fine Zimmer product" when working on my car - the fact that we have nothing but citroens in th efamily is no comfortdocchevron1472 wrote:Like so much on PSA stuff, it's a shame they used crapite and cheesium rather than quality stuff......![]()
Chris G
Luke
Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Toddman
tim leech
