Sorry guys...I know a few of us have a Xantia. I have replaced the lower arm bushes (front and rear) but have a problem with one of the rear bushes. Its the one that fits onto the shaft on the rear of the arm. The bush is turning on the shaft. I understood that these bushes have to pressed onto the shaft and cut off to remove them. i.e. interference fit. I'm on my second bush and that too is not a tight fit.
Can anyone confirm if these bushes are supposed to be pressed on to result in a tight fit??
