Speedo query
Speedo query
Does anyone know if i can fit a n/a diesel speedo to a turbo model? Will it read correctly, i have been informed that a Gti one wont work.
The problem that i have is that the trip is bust on the current speedo that i have, so got the mechanic to have a look & he said the gears were mashed & infact they were catching on the other gears hence the speedo was wobbling.
I dont need a new binnacle as all the rest of the guages work fine, i just need the speedo.
Hoping someone can shed some more light on this!!
tim leech
Any bx speedo will work in any bx but they were matched to the gearing in the diff. Hence a GTi clock will read VERY low on a TD and a N/A clock will be 10mph low, you can overcome this of course by changing the profile of the tyre to suit the speedo but the easiest approach is to get the right speedo head for the car. TD speedo's are available new but they are £250!
As an example, my TD was a N/a car, I fitted speedline alloys with lower profile tyres (195/60's) and the speedo was reading high (indicated 60 when I was only doing 50), fitted the td engine / box and kept the N/A speedo head, speedo now accurate! (I know this cos I had it checked by the guys that do the Tacho's on our buses in work!)
GTi / 16v clocks are not available at all unless you want one to read in Kms / hour.
Chris G
Chris G
Toddman
gearing
Does the speedo drive in the gearbox not have a cog with differing numbers of teeth to alter the speedo reading to suit each differential?
I am too lazy to check the manual
Luke
Luke
Re: gearing
Er, not quite mate..... There are differences in the drive gear in the box but that was purley design alterations over the years, the gearing was always done in the speedo head to compensate for different diffs etc. To make matters more complicated the 16v has 3 different speedo heads despite the gearing being the same that are not interchangable due to the drive piece being different.....Toddman wrote:Does the speedo drive in the gearbox not have a cog with differing numbers of teeth to alter the speedo reading to suit each differential?
If you have access to a N/A speedo and cant find a TD clock then the easiest solution is to fit the N/A clock and wham 60 profile tyres on the car. Hey presto, accurate speedo again!
Chris G
If I come across one I'll fire it your way mate. I'm clearing the garage out this coming week ready for the return of dads BX to Bristol so you night be lucky, theres ALOT of crap in that garage, I may well have a TD clock in stock!
Will PM you if I find one.
Chris G
Chris G
Theres a number on the top right hand corner of the speedo head that identifies it. Cant remember off the top of my head what the number is for a TD though.
That said, I'm afraid I'd forgotten all about the speedo mate. I have a fully functioning TD head in stock!
It's your's for the postage if you want it. The mileage recorder drum is easy to change so you can swap them over and keep the genuine miles on the car!
Chris G
Chris G
Cornishbx16v
what luke said i have heard through a group of pug enthusiasts!
they said that there were a couple of sets of gears that go in the speedo housing on the mi box that alter the speedo reading! (i remember them saying that one was white! and the others obviously wernt!) having never looked i couldnt say but from what they said there are different gears for the box end too!
