Hi,
Just got an old BX16 and the headlights flicker at all revs. This is most pronounced when you open the door as the internal light/s has the same flicker. Great for Haloween but sometimes people even pull over thinking they are being flashed!
Any ideas????
Elec-trickery!
- Keeper of the site Goat
Evening Mr 16, sounds like a possible earthing fault which will hopefully be easy and cheap to sort out. Have you looked at the earthing poin(s?) to see if there`s any sign of trouble? Perhaps where the earth joins the body it`s a bit rusty or frayed?
I`m certain someone more technical than me could shed more light on this (if you`ll pardon the pun!).
Meanwhile welcome along!
Vauxhall apologist.
That the interior lights flicker at the same time suggests its not a headlamp specific wiring fault.
Can I take it they are steady when the engine is not running?
If this is the case I think its an alternator fault - but before condemning it check:
Engine earths and the big plug by the battery - can be done with a meter if you know what you're doing - otherwise take the connector apart and clean it.
Alternator leads.
Does the warning light work properly - ie come on when the ignition is turned on - then go out and stay out?
Is the alternator drive belt tight - and NOT squealing ever?
I had this problem on my TD BX - in fact the lights got better - as the alternator regulator had failed and the thing was probably getting 16 volts or so. The battery was throwing out acid and in fact I could feel the additional drag as the voltage went up and down and slowed the engine. Wipers and flashers were very fast as well.
Alternator leads.
BX16
BX16
Thx guys,
Will check the things out u've suggested at the weekend when I got daylight!. It starts on the button and idles nice and steady. No smoke, rattles etc. Runs nice at 70-80 but doesn't feel smooth. Not exactly missing but I'm now wondering if the two things are related.
Will be in touch....
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
It does sound like your alternator is the culprit. I believe if it is the alternator then the flickering on/off is more of a bright/dim with a regular rythm to it and all electrics would be affected. Does your heater fan sound variable too? If it's not regular and more on/off then suspect earth/connector fault.
