is it a black box thats screwed on the inside of the door card, its got a bunch of wires coming out of it? If its not, what is it?
& what does a window regulator look like?
Window Regulator
sleepy0905
For some reason the window winding mechanism is referred to as the regulator - even when its got a handle for hand winding on it.
Inside a front door you will find the regulator holding the glass and connected to the motor, the locking motor, screwed to the inner face of the door (under the membrane) with 2 screws and a wire link to the locking mechanism, switches and wires - and a control unit if THAT DOOR has one touch windows.
sleepy0905
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I am confused.....You do have a regulator in your door Mulley. As said said, the regulator is a fancy name given to the mechanical device to lift the glass up and down (whether hand wound or electric). Do you need a regulator cos I think I have one??
Black box for one touch is additional electric gizmos - very cool, just fitted one to my TD!!
thanuttiscotsman
tim leech
