Rear Arms
Oscar
Rear Arms
Both rear arm bearings replaced, at last. Taken me a year to cross that job off my list. Also found a bit of rust in the boot pan that i'll get sorted quickly.
Note to anyone thinking of doing them - make sure the bolts are tighter than a tight thing when doing them back up. The near side wheel started leaning back in again 2 weeks after I had replaced the bearings. Before I got the arm off to replace it, I thought "I wonder whether it just needs tightening?" Quarter of a turn later and it all was well.
Stewart (oily!)
ellevie
- Forum Treasurer
When I did mine I bought a torque wrench from Machinemart for about £15 and torqued the nuts up to the prescribe torque, I think it was about 13 kgf m. The torque wrench is handy to have and £15 seemed like a good price. Machinemart p/n CHT141 1/2" drive torque wrench.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
I just do them up TIGHT! I've done hundreds of them and never torqued one up yet (or had one fail).
I always work on the principle that if the bolt snaps, I went a bit too tight!
Chris G
Chris G
Stewart (oily!)
tom
- Citroen Sorceror
- x 94
Geoffrey Gould
Tight!!
Hi Kitch Knowing Doc tight it will be and happy you are ,untill that is you have to UNDO the bl**dy thing.
I have seen Doc go very red and cuss with the words "Who the f*ck did that up ----------" The answer "You did mate."
Cheers.
Geoff.
Cheers.
Geoff.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
tom
- Citroen Sorceror
tom
- Citroen Sorceror
To amplify this in the light of doing one last weekend (50 minutes, new personal best,) The SKF bearings have a different taper to A&S ones and keeping the inner raceways whilst swapping the taper rollers themselves will cause them only to make point contact where they don't go in far enough or float where they go in too far. It is the outer part that wears, so it needs changing. Cut away the tube with a sharp knife and use the old bolt as a drift to extract the raceways. a few smart smacks will drive them out.
