It is well known that the 2.1 can be fitted into a BX but I'm looking at the possibility of a rather simpler conversion. Raising the output to around 110 BHP could of course be done with the pump and turbo but there ain't no substitute for cubic inches.*
How different is the 2.1 south of the head gasket?
*Carroll Shelby.
2.1 engine
tom
- Citroen Sorceror
Tom - there is some XM info (looks like parts lists, manuals etc) on the CitroenY site.
http://citroeny.cz/servis/servis.htm
tom
- Citroen Sorceror
Really, I think that it is all a matter of head bolt patterns. I took a look at the 2.0 HDI.
XUD 90 BHP 185NM at 2,100
HDI 90 BHP 205NM at 1,900
I have no idea of the comparative fuel consumption but despite the torque coming in lower down, the capacity increase has added little torque for the complexity of the HDI. It appears to me as though it is not really a better engine in any respect unless it can push a BX along at 70MPG, which I strongly suspect that it won't.
HHmm, I've been thinking along similar lines.
The 1.7 / 1.9 heads will fit on a 2.1 block.
I'm really not a fan of HDi's at all. Give me a good XU any day.
It's easy enough to get 140BHP from a 17td without spending lots of money but reliability suffers, or at least it did in mine!
I'm still playing around with the setup and will be modding it further next year but at the moment (touch wood!
) it seems happy running 130bhp.
Although I blew the turbo up last week but it was cooked before it went on the new head, new turbo sounds ok!
Chris G
Chris G
M
Me neither and I have two with HDi's - the HDi was designed to be fuel efficient and produce minimal emmissions, thats what all teh complexity is for - more EU red tape making engines more complex / expensive to repair.docchevron1472 wrote:I'm really not a fan of HDi's at all. Give me a good XU any day.
adamskibx
I have heard that the HDi has a bit of a flaw. In order to make it burn correctly for emmision reasons, it has an anti pollution device that contains some special fluid, and this is mixed with the fuel in minute quantities. When the anti pollution fault light comes on, Citroen have to top up the fluid, although it is done at certain service intervals.
Er no mate, it's actually an extract of Goats Urine!
I kid you not. We use it in all the Euro 4 Enviro buses at work! And it stinks like, well, goats pi$$!
Chris G
Chris G
tim leech
Indeed it is a 12valve mate. Whilst the head would fit on a 17 / 19 block, I dont know if the valves would be able to open (especially on the 17) and not sure what power advantage you'd gain.
The 8v head is easily workable, mines got BIG triple angle valves and opened out exhaust ports and it breathes plenty well enough.
Although I am looking into having a cast iron 16V head made for it...
Chris G
Chris G
