Wanted radiator support panel..
tom
Citroen Sorceror
2024. TxD 1.9D estate. 'Wheelybin'
x 12
Post by tom »
..for a TD. The black part that secures with five screws to the bonnet slam panel and carries the intake snorkel and bonnet stay clip.
sleepy0905
Post by sleepy0905 »
I dont know it helps but i have one of a 1.9 NA Diesel you can have for postage.
tom
Citroen Sorceror
x 12
Post by tom »
Thank you for the kind offer Sleepy but the TD one is rather different, alas.
sleepy0905
Ok no problem
Post by ken newbold »
Mulley was also after one of these and after seeing his car today, I think he still is.
x 82
Contact:
got one in the garage, will hunt it out tomorrow and bring it home
tom
Citroen Sorceror
x 12
Post by tom »
Bless you Vanny! Many Thanks! PM me an address so I can send you a postage token!
Hope you've found one Tom - If I had to make one I would use heavy re-inforced rubber sheeting - cut a strip to the correct width - then drill the appropriate holes in it and cut a slot or something for the air intake.
Rubber sheet could probably be obtained from Portmere Rubber which is near Freeborn.
Mine 's been split (for about 1 ft) ever since I've had the car but doesn't seem to be getting worse - but I suppose I ought to drill a hole to stop it getting worse.
