Err.......What's octopuses?
peterbot
Having just aquired another BX (had the last one in the early ninties...a lovley Mark1 TRS) I'm browsing through the forums and keep coming across octopuss repairs....'scuse me being thick but what is it?
Are you sure you need to know. some off these things are best not knowing nuffin about
Simply put its a rubber junction for quite a lot of the LHM return pipes which is conveniantly situated low down behind the engine on top of the subframe and sqeezed between the driveshaft and height corrector. Cost about 25 quid and will pass on a very pleasant afternoons work.
I lied
I lied
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
low pressure return from barkes and other assorted places. Fluid has to run back into the reservoir tank under little or no pressure and does this via rubber hoses. The rubber hoses have a big rubber union in the middle and when off the car if you pick it up by the rubber union block it loosly resembles an octopus with a lot more legs and painful stings!
Anyone got that picture again (think Jon has it?)
- Keeper of the site Goat
I believe it`s the union where all the hydraulic pipes connect and I think there`s two on the cars one front and one rear-someone with more experience (anyone really!) will say for definite.
Welcome to the site anyhow, quite possibly the friendliest and most helpful one you could find. Can you post some pic`s of your car up and tell us a bit about it?
Vauxhall apologist.
peterbot
Thanks guys...Shaln't go proding about looking for that sea creature then. I'll take some photos and put up some imformation about me new Bx at the weekend. It's not a 16v or TD i'm afraid... But a low mileage near mint petrol meteor with a years ticket & 6 months tax for £275 was too good to refuse
Mr B
- Northern Moderator
Yup, don't matter what engine it runs, as cavmad says, it's a BX. Makes a change actually from from all the oilers on here
If you have a look at the green tank on the R/H inner wing, all the pipe work on the top is part of the octopus. It runs along the inner wing and connects on various other components on the front cross member.
1991 Landrover Discovery
1995 VW Golf SE
1995 VW Golf SE
- Our Trim Guru
And then there's the small octopus... which heads down in the direction of the pressure regulator and comes in two different varieties, depending on the age of the car. Not difficult to replace, just maybe a bit time-consuming (like the large octopus). There's an octopus thread on Citroenz at the moment with some wise words from Anders.
- Our Trim Guru
tonym
Hi,
Heres a useful schematic & info. of the main octopus:
http://www.mars.dti.ne.jp/~ynar/bxorg_a ... /m15e.html
Black P2 16V, 82k
Mr B
Can't top that!tonym wrote:Hi,
1995 VW Golf SE
1995 VW Golf SE
- Our Trim Guru
