Retromobile
tom
- Citroen Sorceror
Retromobile
France's old car show. A little small by UK standards but some mouthwatering dream material. I Know that JohnW from Aus is going, the Doc has expressed an interest, I may well be going myself. Paris, Mid February.
- x 94
Hhmm, what needs doing to the valver Kitch....?
I'll be taking the diesel anyhow, the valvers choosy about fuel and continental stuff gives it indigestion!
Chris G
Chris G
- x 94
PAS needs sorting, one of the brakes is binding (might work off if its driven for a while as its been sitting), oil pressure sender needs replacing, the gearbox needs fixing on to the block so that it WILL NOT come off for the rest of the year
Needs a new windscreen, four new tyres + a new rim, rear spheres at the least, maybe fronts and an LHM leak fixed.
Then it needs a major polish/mop. And an MOT and service.
When you coming round?
All simple if pricey stuff then mate!
The most difficult thing on that list is the oil pressure sensor! There a B&$T&RD!
hhmm, end of jan / begining of feb could work!!!
Chris G
Chris G
- x 94
tim leech
- x 94
Its easy as pie mate, seriously the hardest part is getting the coolant hoses off the TB without splitting them, and that only depends on how patient you are.
Once all the bolts are out, you have to give it a wiggle to get it off the dowels, but its all easy. Oh, and leave the fuel rail on....just unplumb the hoses, its the easiest way.
Make sure you've got a new gasket ready to go on. I'm taking mine off again soon to clean it up etc.
tim leech
tom
- Citroen Sorceror
- x 94
