what size pipe seals
charlie
Post by charlie »
does anyone know the sizes of pipe seals for the fdv...
i think theres one 3.5..
and are the others all 4.5...
ta
charlie
yes.....
the colour is....
guiness white..........
tom
Citroen Sorceror
x 38
Post by tom »
I may be wrong but I think some of them are the larger type, about 6mm. It may be a good idea to buy a few spares for the toolkit. I always drop one of them, what ever job I'm doing.
Our Trim Guru
x 13
Post by DLM »
Hi Charlie - I think you'd be safest getting more 4.5s than anything else. Having a variety around is always a good idea.
If you're trying to fix a leaking FDV and think it might be the seals, do check the sides of the FDV for leaks first, as any leaks from the plugs there will most likely need a rebuild of the unit - or a swap if you've got a decent FDV unit spare. [/img]
charlie
Post by charlie »
fitting a new fdv, and was thinking of saving time when i was at gsf and picking up some new seals as well...
basically its mot time and am so fed up with my heavy steering that its time to splash the cash :evil:
and if that dont cure it a new pumps on the way :twisted:
charlie
yes.....
the colour is....
Our Trim Guru
x 13
Post by DLM »
Glad to hear you've got both bases covered, Charlie ...... good luck.
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
When is the MOT mate? Good luck...
charlie
Post by charlie »
well have changed the pump and the fdv with recon ones from gsf and guess what???
still no power steering :(
that only leaves two options ram or pinion valve :roll:
i think a new ram is £80, simple to change so i'm told :roll: :roll:
has anyone rebuilt a pinion valve (kit from gsf?) :roll: :roll: :roll:
trouble is mot ran out last week and i've got limited time with work commitments to spend on the car....
trying to put off a trip to european motors but...
btw seal sizes for the fdv are one 4.5 and four 6mm
charlie
yes.....
the colour is....
How could the ram be at fault if it isn't leaking?
Pinion valve seals can fail, sometimes one side goes before the other - leaving uneven steering. New seals are apparently very difficult to fit. There are some instructions and experiences on here or Frenchcarforum.
