It started after I flushed out the cooling system and put in 2 litres of Antifreeze because the previous Owner was from Auckland which does not get the hard frosts and icey conditions that a Winter near the mountains I work exposes you to.
First signs of a problem after taking it up to 1600m above sea level was a overflow of Green liquid which made my hart stop as I thought the LHM life blood was leaking out the Octopus
When I got it home I noticed that from cold the lower corners of the Radiator were leaking this disappeared after the heat expanded the joints. Whats strange is the problem cured itself in a few days probably silting up? But I did start getting the low level light flashing on! This became annoying as most of the time it was a false alarm.
Replaced the switch which was badly corroded also put in some Rad Leak!
Now this is the part thats bugging me! Sometimes the water level after a long Journey 150 miles the coolant level is fine but if I kick in the Air Conditioning even for a short time then I lose water somewhere?
Checked the Radiator for cool spots and could find nothing.
The local garage said to me it could be signs of early Head Gasket failure
after thoughtCould the Thermostat be clogged or faulty?
