GTi 8v Cambelt Change
Ian_Fearn
Post by Ian_Fearn »
Before i start this is my experience when it comes to changing cambelts:
Once on a Citroen AX 1.1 (35 mins)
Once on a Cavalier 2.0 16v (2 hours)
Twice on a BX TD (down to 40 mins now)
Once on a BX 16v (1h 30m)
So i'm not exactly a cambelt virgin....
Today i changed the cambelt on our GTi. What a bloody nightmare of a job. I started at 10 this morning and finished at 4:30.
OK, i changed the water pump as well (not bled the coolant yet) but SIX and a half hours is mad!
Reasons it took so long:
:x Awkward tensioner setup
:x Hydraulic pump AND alternator belts on the same side on the petrol model
:x Ages spent scraping the old water pump gasket off the block.
:x Sod all access and dropping/lifting the engine gives you no real benefits
NOTE TO SELF: Take it to the garage next time!
Anyway, its now got a new water pump, cambelt, alternator belt, hydraulic pump belt, thermostat and fresh coolant.
Sigh of relief......
Over and out from me
They are a little fiddly, it's so much easier with the engine on the floor!
Give us a shout next time it's due Ian, I got 8V GTi's down to about 40mins now, small hands see!! :lol:
Chris G
Stewart (oily!)
Post by Stewart (oily!) »
That tensioner is a bugger isnt it.no shortage of sharp edges either.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Ian_Fearn
Post by Ian_Fearn »
docchevron1472 wrote:They are a little fiddly, it's so much easier with the engine on the floor!
Chris G
Cheers mate! Its the missus car so it only does about 7K a year now.
In true Ian_Fearn style it had a new tensioner too so as not to skimp!
Tis getting new gearbox oil tommorrow.
