any ideas what offset the bx is? may be looking to upgrade my alloys for something else. my peugeot wheels are 19mm whats the maximum i can go to?????
regards
wheel offset
simonbx17
wheel offset
Current.
Cornishbx16v
the bx has an offset of 15-22 ont he 16v, (more than std. due to the arch extensions) you should find that pretty much all 4 stud pug/citro wheels will fit as they all share the same offsets except for some of the newer models, ford wheels will also fit but you will need a spacer to bring the offset down (adding a spacer reduces the offset figure! ) from 35 to the 15-20 bracket, wheels are quite plentiful in the sizes for the bx as a lot of saxo owners have a habbit of swapping wheels every 5 minutes! ebay is a good bet for them!
i ran mine on 17's for a while! looks the nuts on them! but the 16v has enough grunt to not make them affect performance much at all!
if you type in 'alloy wheel guide' to google then youshould be able ot find a llink to a list with all the makes and models on with the offsets etc! quite handy to have!
simonbx17
offsets
thank you for you help much appreciated
this will help in future swaps.
Current.
