White TZD hatch (with mostly excellent panels) breaking.
Keeper of the site Goat
Post by cavmad »
As above: white TZD hatch breaking for spares. Please note no engine currently available as it`s being fitted to my estate though the 1.7TD will be available soon but it`s very smokey and a pig to start in the cold.
Most panels on the TZD are very good, doors are about as good as you`ll find second hand for example.
Please reply below or pm for any enquiries etc, cheers.
Vauxhall apologist.
RKM
re
Post by RKM »
ANy TZD hubcaps left on it??
Post by cavmad »
Two I think, neither especially immaculate but certainly useable iirc.
Vauxhall apologist.
wannab-x
Post by wannab-x »
Billy, what's the interior like? My other half finds the black interior Aaron fitted into the TZS too uncomfortable for long journeys... :roll:
tim leech
Post by tim leech »
Its the same matey, you need a a twwed interior froma a 19TGD/16TRS/19TZS/19TZD. All TZD turbos had the black Gti style as fitted to your car.
mnde
Meteor Man
Post by mnde »
Billy, does it have a fully working tray clock? (Black)
Mark.
Post by cavmad »
Pretty sure it does Mark but will re-connect a battery to the car and check first.
Vauxhall apologist.
simonbx17
bumpers
Post by simonbx17 »
do you still have the bumpers if so how much?
Current.
Post by cavmad »
I`ll have to check them. I think I have one good front one, not sure about the rear as it may have a crack in it but will find out and let you know mate.
Vauxhall apologist.
RKM
Post by RKM »
where abouts r u for the hubcaps cavmad?
Post by cavmad »
Near to Chester but I think the hubcaps have gone sorry.
Vauxhall apologist.
Hi Cavmad,
do you have a spare psgr side window regulator & the plastic rad cowling cover that fits on the front of the engine bay (not sure of its exact name), it stops the rad from moving about & getting damaged?
Post by cavmad »
I`ll have a good look around the car today and check for all the parts requested above. My apologies for the delay in getting back to you all, been very busy.
Slightly o/t sorry but great to hear from you Mulley and I hope everything is ok with you mate. I`ll pm you when I get a chance, meanwhile it`d be nice to see you back on here a bit more often if you can.
Vauxhall apologist.
Cheers for that, no worries about delays & i will try & get on the forum a bit more....
Cavmad, just realised i could do with the following if available:
Set of headrests (rears preferable), but fronts will be fine.
In the boot where the rear seatbelt goes through the plastic side panel, i could do with that entire upper part of the panel, its the section thats got the parcel shelf spiggot thing that stops the parcel shelf from falling into the boot, guess what, mine is bust.....
Sounds daft, but on the driver side, in the wheel arch there is a plastic guard that protects some pipes near the engine, i need the plastic bolts which hold it in place.
& wait for it, the piece de resistance, i need 1 screw that fits the clock tray & also need the screw which holds the plastic cowling underneath the steering wheel where you can access the bonnet opener & light dimmer.
Of course if i can think of anything else :P
I hope the above makes sense?
