Washers
tim leech
Washers
Post by tim leech »
Mine dont work (front) you pull the tsalk back but nowt happens, no noise no sweep etc, realy works and the fuses seem to be all there?
Doz
Post by Doz »
Pump packed in ??
Check the supply to it when you pull the stick...
Doz
2007 Citroen C1 (it's not a real Citroen)(With a complete set of wheel trims)
2006 C4 1.6VTR+ (Alloys no wheel trims)
1982 Mini HL (No wheel trims, no wheels)
1993 Kawasaki GPZ500
Doz
Post by Doz »
forget that .... no sweep as well.... hmmm switch more than likely ... I think I have a spare in the shed if your want to have a go ...
Doz
tim leech
Post by tim leech »
That would be great thanks, how much do you want? are they a easy job?
Stewart (oily!)
Post by Stewart (oily!) »
Haynes is pretty accurate on the subject Tim, I have a spare switch if needed .
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
tim leech
Post by tim leech »
Thanks guys, Not that I ever use them as I dont take it out when its wet or dirty but even so.
Doz
Post by Doz »
After spending half an hour in the shed (not pleasent) I found a missing set of 1275 con-rods .... and ... unfortunatley ... an indicator switch (Sorry)
Doz
tim leech
Post by tim leech »
Stewart could I purchase one from your goodself?
Stewart (oily!)
I will dig one out tomorrow Tim.
Stewart
tim leech
Post by tim leech »
Ta muchly!
tim leech
Post by tim leech »
many thanks to stewart for supplying a replacement, does the steering wheel have to come off to get the shroud off to change the switch?
Many Thanks
Stewart (oily!)
Not totally sure on that one Tim, try taking the plastic covers off first and see what it looks like, its easy enough to get the wheel off if necessary.
Stewart
Steering wheel should come off by undoing the centre nut and bashing it hard with your hand underneath. Its not a good idea to use the steering lock to hold the shaft - as it could be damaged.
Be careful when replacing the wheel that you don't break the indicator cancelling mechanism tongue - wonder how I fount that one out!
tim leech
Post by tim leech »
OK there easy enough to take off so maybe will do it that way.
st gilles
Post by st gilles »
Just got back from a little ollyday to see this and just in case you've not done it yet Tim, make sure that when you undo the nut on the steering wheel you leave it on there by a half or quarter of a turn......you won't think it would happen but when you bash the wheel from the underneath just to loosen it a little it will (lots of times out of ten) hit you on the bridge of the nose.....good advice given me by an old time mechanic.
