a warm and wet one.
tom
- Citroen Sorceror
a warm and wet one.
Washer, that is. With the weather about to enfold us in lovely slippery snow (There'll be congestion charging for ditches full of X5s,) you might like to take a couple of metres of washer pipe to replace the normal one, wrapping the excess half a dozen times around the top hose and securing it with a good bit of Gaffer tape for a hot washing washer.
Mr B
- Northern Moderator
Mr B
Stewart (oily!)
I buy screenwash by the gallon and use it neat, so far no problems, better to wrap the extra hose around a heater pipe though, the thermostat will not open often in this weather, better still copper pipe around the exhaust, watchout though, my screenwash says flammable on the bottle
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Doz
Saab 900's and (i think) some Volvo's had a pipe build into the exhaust for exactly this purpose... won't help if your bottle is frozen solid though!
Did a similar trick with a mini in the 80's ... quite interesting to see steam coming from the washer jet!!!
Happy snowbx'ing
Happy snowbx'ing
Doz
2007 Citroen C1 (it's not a real Citroen)(With a complete set of wheel trims)
2006 C4 1.6VTR+ (Alloys no wheel trims)
1982 Mini HL (No wheel trims, no wheels)
1993 Kawasaki GPZ500
tom
- Citroen Sorceror
tom
- Citroen Sorceror
Stewart (oily!)
I seem to have a distant emory of seeing a wraparound pipe setup in seventies car mags, heated washer jets are I believe an option on many top end motors, the weak point of the BX is the exposed spraybar, only clever screenwash can avoid this, though warm water might clear the clag more effectively.
Stewart
Stewart
tom
- Citroen Sorceror
As will being a Brita person and filtering the water before putting it into the tank. If your spraybar is clogged up, it can only be due to rubbish in the tank or rust in the spindle of the wiper arm (which is why seasoned BXers run a small drill bit through it annually to clear out the rust and then boil the water before adding it (cooled) to the bottle to help to stop it from rusting in the first place).
Stewart (oily!)
I live in North East Wales where the water quality is so good it is safe to put into lead acid batteries,(according to my old motor vehicle C&G lecturer) Water filters are unneccesary here, washing machines, kettles and showers last indefinitely, In fact its so good we sell our urine to folks like Billy and Vanny to drink (after suitable treatment
) the discussion was on not freezing up, as far as the wiper arm pass through I have always just by-passed it, currently I am using a spraybar from a pug 405, it makes my (neat) screenwash from being wasted, in springtime I merely begin to add water.
Stewart
Stewart
