hurricane clutch
donna
hurricane clutch
hi i have the job to change the clutch on my 1769cc turbo hurricane is this job easy or a bugger to do as it starting to slipp in 4/5 when the turbo kicks in can anyone help thanks gareth
Stewart (oily!)
Deatailed instructions here - and its a TD.
The problem with Haynes is you have to skip between the petrol and diesel books. What's in the petrol book is OK if you know what you're doing - ie can see what's likely to be in the way and know how to remove it.
http://www.bxclub.co.uk/diy/
donna
hurricane
yes itis the winning bidder said his younger son had been messing on the computer and pressed a key by mistake yeh right anyway as im out of work at the moment it gives me somthing to do by doing the clutch ect
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: hurricane
I've heard that excuse before...it was used on something my other half was selling..donna wrote:yes itis the winning bidder said his younger son had been messing on the computer and pressed a key by mistake yeh right anyway as im out of work at the moment it gives me somthing to do by doing the clutch ect
Ah well, good luck with the clutch...
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: hurricane
A superb write up Jon, but, er, there's one critical flaw...
no mention of hammers or gas axe's......
Or is that just me.....
Ooh, the pubs open......
*heads out the door*
Chris G
Chris G
Serious? Rad out??
I just rotate the diff upwards after the box is released from the engine???
Although, the gas axe is just sooooo cool, I cant help myself!
Piccies are always good Jon!
Especially if they're being modelled by nubile young phillies.....
Chris G
Chris G
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Now....Doc...you aint gonna get nubile phillies changing a clutch on ANY car...let alone a BX....so chill baby! (If you have a suitable dream, post it up and give some representative piccies.............ju...tsk......i know what a flamin' clutch looks like! I meant piccies of the....you know......)
Stewart (oily!)
I just crawl under, grab the box, wiggle it and it lands on my chest, then when i get out of hospital
I prop the engine forward using a timber block between the sump and crossmember. I have a first motion shaft cut from a scrap gearbox to centralise the job and away
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
