SQUEALLLLL
tim leech
SQUEALLLLL
Not me but the heater fan in Leader, drives me bonkers, are they the same on Mk1/MK2s or is there a easy fix? It works fine but is so loud it even defeand the transmission!
Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Terry
* I cant recall wot model it is .......its a "J" plate 1.9 deesoil wiv similar dash to my "K" plate BX
capri
Squealing sounds like the bearings in the heater fan. I dunno about BXs, but I do know it's a common fault on Capris, and if it is that that's causing it, there's only one outcome - it'll seize up eventually. If it does, Tim, don't force it - some people will tell you to try putting the heater motor on full to budge it, but it doesn't work. I ended up with smoke pouring out of the dash vents where the motor fried itself.
The easiest bet is probably to fit a new heater blower motor. Either that or you can dismantle the current one and lubricate the bearings in the hope that'll work, but i'd imagine that might only buy you some extra time before it starts happening again.
Also, don't do what I did with the Capri, and buy a dodgy secondhand motor off ebay - after 3 hours' labour to fit the damn thing, I turned it on and it squealed.
1984 Black Ford Capri 2.8 Injection (Specialised Engines Stage II) - Pride & Joy
1996 Hermes Red Citroen Xantia TD SX Estate - Autoroute Cruiser
Stewart (oily!)
tim leech
Stewart (oily!)
I dont think they are, In a Mk2 the fan is the big black thing you can see in the scuttle box where you keep LHM etc, from memory the Mk1 fan is below a kind of grille thing in the centre of the same place, it might be worth checking the drains for dead leaves and stuff as my old Mk1 was prone to these blocking and allowing water to run into the fan.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
If your Mk1 is a C reg, there's a good chance the motor could be the same as the MK2 but seeing as it's squeeling my guess is it's the original Mk1 barrawasted thing to get at.
Like Stewart says, it's located deep down in the hole. My MK1 did this when I got it, WD40 I'm affraid. Yes it will stink for a while, but trust me, it's the only way.
