just a quick question from a long time lurker
the lh driveshaft on my tgd turbo is on the way out, wilst searching all the usual suspect for a replacement i noticed that ecp have an abs spec one for £35, can i fit this (easily
cheers
Peugeot use 2 different types of ABS shaft. There's the fine tooth and the coarse tooth. One is for Bendix ABS, the other for Bosch (although I can't remember which way round they are.)jeremy wrote:Presumably its the ABS ring that stops us getting for example a Peugeot shaft and changing the joints over and using our original and hopefully straight shaft. The problem here is presumably that Peugeots use a coarser ring for a different ABS system.
